You are here: PSPad forum > English discussion forum > String converters applied in reverse order
#1 String converters applied in reverse order
Posted by: cincura.net | Date: 03/15/2018 15:40 | IP: IP Logged
PSPad 5.0.0 (267) 64b
Using the default `Template.in_` and selecting the backward direction converts converts from `dear` to `hippopotamus`. I expect this to be left-to-right direction.
#2 Re: String converters applied in reverse order
Posted by: Andreas | Date: 03/15/2018 19:16 | IP: IP Logged
This is a duplicate. I've already reported it in this ticket
forum.pspad.com
#3 Re: String converters applied in reverse order
Posted by: pspad | Date: 03/15/2018 19:23 | IP: IP Logged
And I have it still marked as unresolved winking smiley
#4 Re: String converters applied in reverse order
Posted by: pspad | Date: 03/27/2018 08:09 | IP: IP Logged
cincura.net:
It wasn't simple "switched". I added possibility to use only one direction conversion and it causes problems. Will be solved in the new build
