You are here: PSPad forum > English discussion forum > version with column selection working?
#1 version with column selection working?
Posted by: charonme | Date: 12/01/2017 10:51 | IP: IP Logged
is there a version where the column selection feature works?
I get completely garbled text when trying to use it in 4.6.1 and 4.6.2
#2 Re: version with column selection working?
Posted by: Gabriel_ACE | Date: 12/01/2017 13:07 | IP: IP Logged
charonme:
what???
in wich case??
I use it all the time and do the work perfectlysad smiley
#3 Re: version with column selection working?
Posted by: Gorlash | Date: 12/06/2017 23:55 | IP: IP Logged
I've had this issue in the past. For me, it occurred when I had code where some lines had hard tabs and others had spaces (this is a common artifact when editing other peoples' code). Then doing column-mark-and-delete can actually delete the first character of un-marked data on *some* of the lines, which makes recovery quite interesting. Also, undo doesn't always properly restore things.
