You are here: PSPad forum > English discussion forum > FTP: File save error
#1 FTP: File save error
Posted by: code tzar | Date: 11/14/2017 22:24 | IP: IP Logged
what is the most common reason for this in Pspad?
I don't think this is a pspad problem, I think it's a server problem. But I get the window saying that there is a File save error every time I try to save to my server. It just started happening after a server reboot and I'm trying to figure out why. I am also looking into cPanel forums, but I wanted to ask here as well. Thank you in advance!
#2 Re: FTP: File save error
Posted by: pspad | Date: 11/15/2017 06:02 | IP: IP Logged
Hello. What is your server operating system? Linux/Windows?
Maybe there is a problem with rights.
For Linux try: Program settings / Direct edit button
set DontChangeFileAttribs = 1
or if it doesn't help:
SafeFileChange=1
The second option if file already exists will create temp file, delete original and rename temp file to original name.
#3 Re: FTP: File save error
Posted by: code tzar | Date: 11/15/2017 13:00 | IP: IP Logged
SafeFileChange=1
My home operating system is Windows, the remote server is Linux.
Here's the thing: when I connect to any other remote server, I can save with no problems. So it is just my remote server that seems to have this issue. I tried setting permissions for the directory to 777, still cannot save!
#4 Re: FTP: File save error
Posted by: code tzar | Date: 11/16/2017 20:43 | IP: IP Logged
It turns out that this is an issue due to running out of space on my remote server. Once I cleared out some backups I didn't need and other useless large files or directories, everything went back to normal.
It'd be a great feature to have the PsPad message tell me that there wasn't enough space to save the file! smiling smiley
