You are here: PSPad forum > English discussion forum > Re: Definition file macros and other commands
Posted by: clanman | Date: 2017-11-09 01:31 | IP: IP Logged
I am sure this has been raised before however I am unable to find anywhere that clearly outlines all the things you can do in the definition (.DEF) files.
Examples:
1. Adding a pipe (|) instructs PSPad to place the cursor at that location. How do I tell PSPad to put a pipe character on the line.
2. There are many macro (@E, @O and so on) options. Where can I find the complete list and a description of their value functions.
3. I want to put an example of what to type and have this removed once typing starts. Is this possible?
Posted by: pspad | Date: 2017-11-09 05:41 | IP: IP Logged
Most of information you want tou will find in the help under Working with PSPad / Context files / Interactive clips
Posted by: clanman | Date: 2017-12-07 04:39 | IP: IP Logged
Thanks very much Jan
