You are here: PSPad forum > English discussion forum > Re: Duplicate Line behavior change
#1 Duplicate Line behavior change
Posted by: massimobalestra | Date: 2017-10-27 18:31 | IP: IP Logged
I saw a change in the Duplicate Line function.
If I select something in a line and I choose Duplicate line (for me it is the shortcut ctrl+D) it duplicates the line without the highlighted part.
This is a change from previous versions: before it simply duplicated the line as it was.
And it is quite annoying for me: I often use to search for something, duplicate the line (as it is) and change few things and go ahead on my search.
Now before duplicating the line I have to be careful that nothing is highlighted before duplicating because otherwise the line is only partially copied (it is not duplicated, it is copied with changes).
Is there a way to go back to the previous behavior? Is there an option "Duplicate line duplicates the line regardless of what is highlighted"?
Thank you
#2 Re: Duplicate Line behavior change
Posted by: Andreas | Date: 2017-10-29 12:27 | IP: IP Logged
I can not confirm this on 5.0.0 235 32-bit Windows 10.
#3 Re: Duplicate Line behavior change
Posted by: massimobalestra | Date: 2017-10-30 15:50 | IP: IP Logged
I have Windows 10, PsPad 5.0.0 (251).
As I said it is change in one the latest version, probably the last one.
This behavior was for sure not present in built 235.
Edited 1 time(s). Last edit at 2017-10-30 15:51 by massimobalestra.
#4 Re: Duplicate Line behavior change
Posted by: Ilya | Date: 2017-10-31 06:34 | IP: IP Logged
I can confirm this on 251 64b.
If you select all characters in the line (or select whole line) then a new empty line is added.
#5 Re: Duplicate Line behavior change
Posted by: pspad | Date: 2018-02-17 19:23 | IP: IP Logged
Bug fix will be availble in the next build
#6 Re: Duplicate Line behavior change
Posted by: massimobalestra | Date: 2018-02-18 18:51 | IP: IP Logged
The old behavior is back, now, on build 261.
This works way better for me. If I want to duplicate a line I want to do it regardless of what I have selected.
Thank you very much.
