You are here: PSPad forum > English discussion forum > How to combine several regular expressions
#21 Re: How to combine several regular expressions
Posted by: maki | Date: 2017-10-30 11:34 | IP: IP Logged
However, it is not possible to change the *.log file to plain text.
Theoretically, you can only extract text from a file, but I can never clear the full code and I have to manually remove hundreds of thousands of unnecessary code.
this is a massacre job.
Log register all content of any page (if supported).
I have a parser that, in addition to the connection log and executable, contains useful text (for example, descriptions from the social network)
Mini-example:
1481405751408-12/10/16 10:35:51 [jd.http.Browser(loadConnection)] ->
{"response":[17129,{"id":,"to_id":-26,"date":14,"post_type":"post","text":"#БП_Россия<br><br>Анонимно пожалуйста...<br><
Edited 1 time(s). Last edit at 2017-10-30 11:36 by maki.
#22 Re: How to combine several regular expressions
Posted by: pspad | Date: 2017-10-30 12:19 | IP: IP Logged
As the first, you need to open LOG in correct encoding.
If there is mix of UTF-8 and ANSI, you can't open it as UTF-8
In my last answer I wrote you how to reopen file in correct encoding.
Without knowledges of your file content or without sample, I am not able to help you more.
#23 Re: How to combine several regular expressions
Posted by: maki | Date: 2017-10-30 14:33 | IP: IP Logged
EmEditor correctly opens the file, automatically detecting the encoding as UTF8
Sample text
<br>А __<br>Так же ", \"сонный\", \" убитый\". Глупоо человек доверяет мне.<br>
need to correct the regex
<br>text<br>
and <br>text</br>
(?<=<br>)[^\\\[\]\{\}]*?(?=(</br>|<br>))
I do not know what will be the best option for extracting text because I do not want to mix text that contains a very long text line 10000+
My Set view:
Wrap by Characters
Issue 2:
Try to open the wrong encoding (can not correctly select the text)
Reproduction: Please broken CHARSET and open and try to mark the damaged charset
Edited 3 time(s). Last edit at 2017-10-30 14:40 by maki.
#24 Re: How to combine several regular expressions
Posted by: maki | Date: 2017-11-01 09:13 | IP: IP Logged
@pspad - This is a bug !!!
Please copy the text to the program and try to select. Will not succeed !!!
I checked this and it is a real bug. Why not fix it?
Copy/paste text:
pastebin.com
I need to fix the charset automatically, but I do not know if there is such a way in PSPad?
Unknown Encoding/Decoding to Russian Encoding/Decoding etc.
#25 Re: How to combine several regular expressions
Posted by: pspad | Date: 2017-11-01 09:24 | IP: IP Logged
Of course is hard to select such text, cause due to wrong encoding it contains control chars.
I tried to get wrong encoded text, but I wasn't successful. PSPad detected correctly azbuka and UTF-8. Can you prepare me some sample what is wrongly detected?
Without it I can't do nothing.
#26 Re: How to combine several regular expressions
Posted by: maki | Date: 2017-11-01 10:08 | IP: IP Logged
or
(?<=<br>)[^\\\[\]\{\}]*?(?=(<\/br>|<br>))
Regex does not work properly because the text is \
What should be changed in regex?
I will not send you the whole file because it contains private data in huge quantities,
But what should I send to show bad coding? Because it shows.
#27 Re: How to combine several regular expressions
Posted by: maki | Date: 2017-11-01 10:11 | IP: IP Logged
example: www33.zippyshare.com
#28 Re: How to combine several regular expressions
Posted by: pspad | Date: 2017-11-01 10:38 | IP: IP Logged
Just tested. When I save it as ANSI 1251, PSPad isn't able to detect correct encoding cause there isn't enough cyrilic characters.
In this case I change encoding in menu Encoding to Ansi 1251 and reload (Ctrl+R) to see correct content
When I save your sample to UTF-8 no BOM and reopen it. PSpad open it correctly as UTF-8 file.
#29 Re: How to combine several regular expressions
Posted by: pspad | Date: 2017-11-01 10:41 | IP: IP Logged
maki:
or
If you want to search for '\' char, you need to escape it with '\' char. It means you will use \\, not a \\\
#30 Re: How to combine several regular expressions
Posted by: maki | Date: 2017-11-01 10:52 | IP: IP Logged
Now differently, it detects, again wrong
"РѕР ± СЂРѕРіРѕ РІСЂРμРјРμРЅРё СЃСѓС,РѕРє." РќРμС,
Too bad it does not automatically detect encoding.
Without unnecessary switching coding.
PSPad - wrong detect encoding
Notepad ++ (Plus) - correct encoding
EmEditor - correct encoding
Edited 1 time(s). Last edit at 2017-11-01 10:54 by maki.
