You are here: PSPad forum > English discussion forum > How to combine several regular expressions
Posted by: pspad | Date: 2017-10-26 15:14 | IP: IP Logged
Can you send me any sample of your text file to support mail?
Edited 1 time(s). Last edit at 2017-10-26 17:21 by pspad.
Posted by: Andreas | Date: 2017-10-26 20:08 | IP: IP Logged
pspad:For 64b version you need to replace files with 32 b version first and than replace EXE. You will get localized PSPad will all missing functionality
I tried the 64b version. Is it right, that I only have to replace the PSPad.exe from 64b download zip (as there is only this one file in it)?
I don't know what you mean with "replace files with 32 b version first".
And is this correct, that I have no scripting with 64b so that I e.g. can not use my "Multiline Search / Replace" plugin?
I don't know what this means "PSPad will all missing functionality".
Posted by: pspad | Date: 2017-10-26 20:42 | IP: IP Logged
64b version is for testing. 32b zip contains changet files in compare to latest full vrsion. So you need to unpack and replace your current version with content of the 32b archive and as another step replace exe with 64b version to get all functionality.
Yes, you are right. 64b version doesnt supports scripting yet.
Posted by: Andreas | Date: 2017-10-26 22:37 | IP: IP Logged
Ok, thank you.
BTW I switched back from 5 251 to 5 235. 251 produces to many freezes. Don't know why and when.
Then I experimental used the 251 64b with 235 32b. But it's not good for me, I need my plugins for daily work.
Posted by: pspad | Date: 2017-10-27 03:24 | IP: IP Logged
Did 251 really freezes for you?
it will be very useful for me let me know what do you do. Code explorer?
Posted by: Andreas | Date: 2017-10-27 13:06 | IP: IP Logged
pspad:Did 251 really freezes for you?
If I only would knew this. Code explorer some times. CPU is on about 40% and will not stop. It seems to happen suddenly.
i7-6500 CPU 2.59GHz
8GB RAM
Windows 10 64-Bit
Portable with all rights
About 1-20 not really big files opened
Use FTP without SSL/TLS as this seems to caused problems earlier
Tried to use the latest SSL/TLS-DLLs
You want to see my PSPad.INI?
BTW Could you please change code explorer behaviour so that classes are opened by default as in earlier versions (PHP)?
Edited 2 time(s). Last edit at 2017-10-27 13:08 by Andreas.
Posted by: pspad | Date: 2017-10-27 13:13 | IP: IP Logged
Each syntax has different behavior. What syntax do you talking about?
Posted by: Andreas | Date: 2017-10-29 11:44 | IP: IP Logged
Talking about PHP as mentioned in my post between brackets.
Posted by: maki | Date: 2017-10-30 10:16 | IP: IP Logged
64-bit PSPad
Open this text and try to select it.
Text is moving! <===(this is a bug)
Very easy reproduce.
Posted by: pspad | Date: 2017-10-30 10:46 | IP: IP Logged
maki:2) Open UTF-8 file or CP-1251 (log file). Text encoding wrong !!!
Please fix this.3)I want to mark the wrong encodin Note: 2), the text is moving. Very stupid strange bug.
I still do not know how to remove 100% of log code, html and xhtml.
I am not able simulate it. Current PSpad 5 detects cyrilic and UTF-8 correctly.
Ensure Autodetect option in menu Encoding is checked.
In case PSPad doesn't open file correctly (wrong encoding), choose correct encoding in the Encoding menu and reload file (Ctrl+R)
