You are here: PSPad forum > English discussion forum > Re: reformat html code
Posted by: techpaul702 | Date: 2017-10-12 22:48 | IP: IP Logged
When I load a .html or .htm file the reformat html function is available.
How can I make the reformat html available when I load a .aspx file
Posted by: pspad | Date: 2017-10-13 03:58 | IP: IP Logged
Check on the status bar, if there is used highlighter for HTML or any web scripting language.
If not, you assign extension to any highlighter what PSpad doesn't recognize as HTML based.
You can anytime change highlighter with tool bat change syntax button or use menu from HTML menu
Posted by: techpaul702 | Date: 2017-10-13 17:03 | IP: IP Logged
I just added *.aspx to html highlighter section as you said
and it works perfectly.
Thank you
Posted by: pspad | Date: 2017-10-13 20:16 | IP: IP Logged
Maybe better will be add ASPX as highlighter for <? ?> in program settings / Multihighlighter. This will embed your scripts in HTML and starts consider ASPX as HTML family language
