You are here: PSPad forum > English discussion forum > reformat html code
reformat html code
#1 reformat html code
Posted by: techpaul702 | Date: 10/12/2017 22:48 | IP: IP Logged
When I load a .html or .htm file the reformat html function is available.
How can I make the reformat html available when I load a .aspx file
#2 Re: reformat html code
Posted by: pspad | Date: 10/13/2017 03:58 | IP: IP Logged
Check on the status bar, if there is used highlighter for HTML or any web scripting language.
If not, you assign extension to any highlighter what PSpad doesn't recognize as HTML based.
You can anytime change highlighter with tool bat change syntax button or use menu from HTML menu
#3 Re: reformat html code
Posted by: techpaul702 | Date: 10/13/2017 17:03 | IP: IP Logged
I just added *.aspx to html highlighter section as you said
and it works perfectly.
Thank you
#4 Re: reformat html code
Posted by: pspad | Date: 10/13/2017 20:16 | IP: IP Logged
Maybe better will be add ASPX as highlighter for <? ?> in program settings / Multihighlighter. This will embed your scripts in HTML and starts consider ASPX as HTML family language
