You are here: PSPad forum > English discussion forum > Re: crlf in assembly
Posted by: jpsdjs | Date: 2017-10-04 17:36 | IP: IP Logged
I can no longer use Notepad++. It had a nice feature that helped make the
source file shorter. You could move the crlf at will.
How can I do this in pspad?
Thanks for pspad and this site.
Posted by: pspad | Date: 2017-10-04 20:08 | IP: IP Logged
What do you mean "move the crlf at will"?
Can you explain it more please?
Posted by: jpsdjs | Date: 2017-10-05 11:35 | IP: IP Logged
In Notepad++ using an assembler language it was possible to shorten
the length of the program by making visible the "CRLF" at the end
of each line. In other words if the line was 40 bytes long and the
crlf was sitting at position 72 then the crlf could be moved to
position 41 making the program 30 bytes shorter.
Notepad++ also gave the option to turn this option
on or off.
If you need more information about this I will try to comply.
Thanks for answering.
Edited 1 time(s). Last edit at 2017-10-05 11:39 by jpsdjs.
Posted by: pspad | Date: 2017-10-05 11:55 | IP: IP Logged
To see white chars, use paragraph toolbar button (same as e.g. in the Word) or menu View / Special chars
To remove additional spaces from the begin/middle/end of line, use function from the menu Edit / Line manipulation / Remove redundant spaces
For faster access, you can assign shortcut for this function in the program settings / Key Map. Personally I use Shift+Ctrl+Q
Posted by: jpsdjs | Date: 2017-10-05 20:48 | IP: IP Logged
I thank you very much for helping.
There are so many buttons on the editor and I am
very new at using the editor. I was unable to follow your
instructions.
Would you be so kind as to state them in a different manner?
Posted by: pspad | Date: 2017-10-05 21:12 | IP: IP Logged
jpsdjs:I thank you very much for helping.
instructions.
1. You want to see CrLf.
Go to menu View and click on the Show hidden chars
2. You want to remove redundant spaces on the end of lines
Go to menu Edit / Line manipulation and click on the Remove redundant spaces
I am sorry, but I don't know how to write it better way.
Posted by: jpsdjs | Date: 2017-10-06 15:27 | IP: IP Logged
Thanks very much for helping.
It's not the same but the special character you have used
means the same thing and it works for me.
Posted by: jpsdjs | Date: 2017-10-06 19:40 | IP: IP Logged
It would be nice if I could get rid of the "."s between each word.
But the end if line problem is solved.
Couldn't find out how to edit the previous message.
