You are here: PSPad forum > English discussion forum > Re: How can i delete lines that begins with the same string ?
#1 How can i delete lines that begins with the same string ?
Posted by: Esgrimidor | Date: 09/12/2017 20:35 | IP: IP Logged
HOw can i deleted lines that begins with a proposed same string ?
Best Regards
Nice program indeed
#2 Re: How can i delete lines that begins with the same string ?
Posted by: vbr | Date: 09/12/2017 22:10 | IP: IP Logged
Esgrimidor:
Best Regards
if you just want to delete the content of all lines starting with some given string, you can use regular expression replace (Ctrl+H), e.g.:
^Beginning_of_a_useless_line.*$
replace using regex with an empty string.
^matches at the beginning of the line
$ matches at the end of the line
. matches any character except of newline
* is a quantifier for "any number" - zero or more - of the preceeding element
note that in PSPad, you currently can't match the whole line including the newline character at the end, hence, after a replacement above you get an empty line but the ending newline stays there.
hth,
#3 Re: How can i delete lines that begins with the same string ?
Posted by: Esgrimidor | Date: 09/16/2017 21:51 | IP: IP Logged
Thanks a lot.
Nice program indeed
