You are here: PSPad forum > English discussion forum > Re: User Highlighter
Posted by: Gabriel_ACE | Date: 2017-09-08 13:58 | IP: IP Logged
Hi
if a change for example
in REXX.INI "Comment Style"
like /* */ to /+_+/
in the file REXX.INI only apear
CommentString=/* */ (I never saw the result in the REXX.INI file)
my cuestion is:
WHERE I CAN SEE THATS CHANGE ?!?!?!?!?!?
because I need to hardcore a Comment Style thats is not on the LIST
THZ
Edited 1 time(s). Last edit at 2017-10-05 06:38 by Stefan.
Posted by: pspad | Date: 2017-09-08 15:43 | IP: IP Logged
Menu Settings / User highlighter.
Open REXX highlighter and set comment style as you need. /+ ... +/ is available.
If you have PSpad installed in program files, run it as admin, to be able save highlighter definition there
Posted by: Gabriel_ACE | Date: 2017-09-08 15:55 | IP: IP Logged
pspad:Menu Settings / User highlighter.
/+...+/ it is an example
I need set "ñ_ñ", but it is not there, so how can I set comment that is not enabled
I am using portable pspad
Posted by: pspad | Date: 2017-09-08 16:28 | IP: IP Logged
User highlighter allows to use only predefined set of comments.
Syntax highlight will be fully user customizable in future after editor engine exchange.
Posted by: Gabriel_ACE | Date: 2017-09-08 17:38 | IP: IP Logged
pspad:HelloUser highlighter allows to use only predefined set of comments.
THZ for the explanation
