You are here: PSPad forum > English discussion forum > Re: How to automate many different replaces in PSPad?
Posted by: therium | Date: 2017-08-27 16:13 | IP: IP Logged
I have about 10 files where I have to make about 10 different replaces, replacing "smart double quotes" with low-ascii equivalent. I would like to just run a single command containing all these replaces when I first edit a file. The file is markdown and I will also be using regex to do other replaces like to convert footnotes to Markdown footnotes, like:
"[24]" converts to "[^ch01-24]".
Can PSpad do this some how? I don't want to use the macro recorder because if I get one thing wrong, I have to re-record from the beginning again, and that's a PITA.
Or is there an addon/extension to do this in PSPad?
Thanks.
Posted by: pspad | Date: 2017-08-27 18:05 | IP: IP Logged
Hello. Look at user convertor. Pspad 5 supports regular exceptions. In the convertor folder is file Template.in_ with some description
Posted by: Andreas | Date: 2017-08-28 14:33 | IP: IP Logged
But we only can do this with a single file, right?
Posted by: pspad | Date: 2017-08-28 16:26 | IP: IP Logged
With script ypu can run convertor for all open files. As example use print all script and exchange pspad command
Posted by: vbr | Date: 2017-08-29 11:37 | IP: IP Logged
therium:Hi,
I have about 10 files where I have to make about 10 different replaces, replacing "smart double quotes" with low-ascii equivalent. I would like to just run a single command containing all these replaces when I first edit a file. The file is markdown and I will also be using regex to do other replaces like to convert footnotes to Markdown footnotes, like:"[24]" converts to "[^ch01-24]".
Thanks.
You can use a custom script for such repeated tasks.
Just check:
Program settings: [x] System integration: Integrated scripting support (WSH)
There is a documentation in the PSPad folder
...\PSPad\Scripting.rtf
including a sample file in vbscript for running a converter on all open files;
You can group the respecive files with sessions or as a project.
Alternatively, if you prefer to have a single batch-like file to manage such conversions, it can be via scripting entirely.
Just save the javascript (preferably utf-8 encoded) e.g. as:
...\PSPad\Script\JScript\batch_conversion_re.js
Quote:var module_name = "BatchConversionRE";
var module_ver = "1";function reBatchReplaceMultiple(){
var fileList = ["C:\\path\\to\\a.txt","C:\\path\\to\\z.txt","C:\\path\\to\\b.txt","C:\\path\\to\\c.txt"]; // paths with double backslashes
for (var i=0; i < fileList.length; i++){
var filePath = fileList[i];
var actEd = newEditor();
try{
actEd.openFile(filePath);
}catch(e){
continue; // skip missing files
var outputTxt = actEd.text(); // replacements on the whole text
//series of replacements
outputTxt = outputTxt.replace(/[“”„“]/gi, "\"");//quote as needed: slashes in search patterns \/ quotes in replacement patterns: \"
outputTxt = outputTxt.replace(/[‘’]/gi, "'");
outputTxt = outputTxt.replace(/\[(\d+)\]/gi, "[^ch01-$1]");
actEd.text(outputTxt);
actEd.setCaretPos(0,0);
actEd.saveFile(); // (un)comment as needed
// actEd.closeFile(); // (un)comment as needed
}function Init(){
addMenuItem("Multiple batch replace RE", "", "reBatchReplaceMultiple","Ctrl+Alt+Shift+H");
After saving the script file in the mentioned location, you have to call Scripts: Recompile scripts, and the menu item should appear whithin scripts (and the shortcut is assigned).
The script should be tweaked to match your data, paths and needed conversion; you can assign another shortcut too (provided there is no collision with system,program, code clips or other scripts' shortcuts).
hth,
Posted by: therium | Date: 2017-09-13 15:13 | IP: IP Logged
Thank you. Is that VBScript you gave me?
Posted by: vbr | Date: 2017-09-13 16:05 | IP: IP Logged
therium:Thank you. Is that VBScript you gave me?
Hi, You are welcome;
it is javascript; like VBScript, it should be supported by default on windows WSH.
The script file must be placed in the appropriate folder, e.g.:
... Script\JScript\
(either in PSPad Program folder or possibly in the user profile folder).
hth,
