You are here: PSPad forum > English discussion forum > Re: How to add a new Context\Markdown.def file?
Posted by: therium | Date: 2017-08-25 12:16 | IP: IP Logged
PSPad 4.6.2
I'm trying to add a new Context\Markdown.def file. I copied it from Perl.def, then restarted PSPad, but the Markdown.def file is not appearing under the menu Settings, Edit Clip Definition file. How can I get my Markdown.DEF to appear here so I can edit and use it in PSPad?
Posted by: pspad | Date: 2017-08-25 12:39 | IP: IP Logged
You need to assign user syntax definition into free slot in the Settings / Highlighter settings. Don't forget chech checkbox before highlighter.
It suppose that syntax definition exists in the Syntax subfolder.
Posted by: therium | Date: 2017-08-26 17:49 | IP: IP Logged
Got it. Thank you.
Posted by: Yaz | Date: 2018-03-06 20:49 | IP: IP Logged
therium, would you be willing to share your Markdown def and template files on this post? I have been trying to create my own, to no avail. Thank you.
Posted by: brokengillou | Date: 2018-07-08 16:17 | IP: IP Logged
Yaz:therium, would you be willing to share your Markdown def and template files on this post? I have been trying to create my own, to no avail. Thank you.
brokengillou:Also interrested
Posted by: pspad | Date: 2018-07-08 16:26 | IP: IP Logged
Definition (code template) files are fully user customizable. All are placed in the .\Context folder - text files with DEF extension.
Syntax of files is described in the help
You can add your own template very easy by selecting text and pressing Ctrl+Alt+Space
The only ptroblem is if you have PSPad installed in the Program files folder, you can't write there directly. You need to run PSPad as admin or move PSPad out of PF folder.
