You are here: PSPad forum > English discussion forum > Re: Add Code Explorer suppord for AutoIt
#1 Add Code Explorer suppord for AutoIt
Posted by: Parazit | Date: 08/03/2017 09:25 | IP: IP Logged
Hello.
I have been working on Autoit for a long time.
The PSPad is the only IDE I use.
To me, as well as to the whole community of Autoit, there are not enough functions that would help GoTo the project faster.
Click to Names, and jamp to Function.
Thanks.
Edited 1 time(s). Last edit at 08/03/2017 09:26 by Parazit.
#2 Re: Add Code Explorer suppord for AutoIt
Posted by: pspad | Date: 08/03/2017 10:50 | IP: IP Logged
PSPad supports Code explorer for AutoIT. I just tested it with PSPad 5 and your example and I was able to see functions in the Code explorer
Go to menu Settings / User Highlighter
Open AutoIT3 definition
In the middle is Code explorer assignment, for AutoIT there should be ftAutoIT
If PSpad is installed in program files, you need to run is as administrator to be able save syntax definition in Program files
#3 Re: Add Code Explorer suppord for AutoIt
Posted by: Parazit | Date: 08/03/2017 11:20 | IP: IP Logged
I understood. Thanks.
