You are here: PSPad forum > English discussion forum > Re: php compiler not active on open of php file.
Posted by: jtaubman | Date: 2017-07-14 16:26 | IP: IP Logged
I see this was reported previously, having just tried 5.0 I see it also has the same problem, at least for me.
Which is if I open a .php the compile button does not go active, but if I then go into Highlighter settings and simply press OK the buttons become active and work fine.
Is there a setting somewhere I can change to get this to work on the opening of a file. I did try to search but could only find reports of the problem and not the solution.
Posted by: vbr | Date: 2017-07-14 16:54 | IP: IP Logged
jtaubman:> php compiler not active on open of php file
is the highlighting of the code working in this case (before confirming the highlighter settings)?
If not, it might be due to the file size - for larger files the highlighting is initially deactivated for faster opening the code.
You can adjust the limit for automatic highlighting after loading the file in
Settings... [Direct edit]
Special settings:
HLOnUpToSize=500000
(filesize in bytes)
This might work the same in PSPad 4 and 5.
hth,
Posted by: jtaubman | Date: 2017-07-14 17:38 | IP: IP Logged
Highlighting is done, it's just the compiler button which does not activate. Just tried it with a 40 line php script.
I have been playing while I waited and I have just noticed it's using the "HTML Multi-highlighter" so I obviously need to change that somewhere. I have checked the HTML highlighter and that does not include .php, can you point me in the right direction please.
edit: Don't worry I have turned off the Multi-Highlighter. So the PHP highlighter with the Compile is now in place.
So the problem seems to be if Multi-Highlighter is set to work with PHP files, the Application and Compiler options from the PHP settings are not applied until you edit the Highlighter settings for PHP.
Thanks
Edited 1 time(s). Last edit at 2017-07-14 17:44 by jtaubman.
Posted by: pspad | Date: 2017-07-14 17:50 | IP: IP Logged
jtaubman:Highlighting is done, it's just the compiler button which does not activate. Just tried it with a 40 line php script.I have been playing while I waited and I have just noticed it's using the "HTML Multi-highlighter" so I obviously need to change that somewhere. I have checked the HTML highlighter and that does not include .php, can you point me in the right direction please.
Thanks
If you want to use PHP with multihighlighter, assign PHP to HTML highlighter. Compiler must be assigned to BASE highlighter. In multihighlighter, PHP is opne of the embeded scripts only.
Posted by: jtaubman | Date: 2017-07-14 22:41 | IP: IP Logged
Thanks I will give that a try.
