You are here: PSPad forum > English discussion forum > White rectangle/gap between file tabs and project/editor area
#1 White rectangle/gap between file tabs and project/editor area
Posted by: padfox | Date: 2017-07-07 21:52 | IP: IP Logged
I have many opened files (about 200) in my PSPad project. Even when I move/minimize/maximize the PSPad window on a monitor that large rectangle/gap (about 3cm in height) is still existing. Moving to another monitor doesn't solve the problem either.
When I close one tab, the rectangle/gap disappers. But after moving the window it is again visible.
I'm using version 4.6.3 (2750), but had the same problem with a rather old version, too.
Any hints are highly appreciated!
Many thanks and greetings
padfox
#2 Re: White rectangle/gap between file tabs and project/editor area
Posted by: pspad | Date: 2017-07-08 04:32 | IP: IP Logged
Many problems were fixed in the PSPad 5. You can download it in the developer forum
