You are here: PSPad forum > English discussion forum > Re: Plans to change background of active tab?
Posted by: therium | Date: 2017-06-12 12:04 | IP: IP Logged
I have PSPad 4.6.2 (2750). I can't see how to change the active tab's background color. The active tab background is dark gray, and inactive tab backgrounds are light gray. I'd like to make the active tab's background light green, or some shade of green.
Is this possible now, or can this feature be added later?
Posted by: pspad | Date: 2017-06-12 12:42 | IP: IP Logged
Active tab background depends of the Windows theme.
PSPad allows you change partially look in the program settings / Direct edit:
HighlightCurrentFileTab=1
this option switch on/off current tab highlight. Background is given by Windows theme
MarkCurrentFileTab=0
this option underline current file tab
Maybe if you will change value for both options (first to zero, second to 1)...
Posted by: therium | Date: 2017-06-14 10:59 | IP: IP Logged
Some editor widgets allow you to change the tab background color. I was just wondering.
MarkCurrentFileTab=1
works better. Thanks.
Posted by: pspad | Date: 2017-06-14 11:05 | IP: IP Logged
It was solution which can help you immediately. It's no problem to add option for current File tab color.
