You are here: PSPad forum > English discussion forum > Re: Default file open directory
#1 Default file open directory
Posted by: swbrains | Date: 05/21/2017 14:48 | IP: IP Logged
I am using 4.6.2 (2750) on Windows 10. My program settings have "Designate Directory" selected. But if I open a file in directory "abc" (not my designated directory) and then close PSPad, then reopen PSPad, then click the open button, the open dialog defaults to "abc" folder again rather than the designated directory in settings.
#2 Re: Default file open directory
Posted by: pspad | Date: 05/21/2017 15:00 | IP: IP Logged
I just tested it with current PSPad 5 build (available in the PSpad developer forum) and it works as should. I did what you did and when I run PSPad next time, the Open dialog starts in the folder what was filled in program settings as the designated directory
