You are here: PSPad forum > English discussion forum > Version 5 compiler launch
#1 Version 5 compiler launch
Posted by: swbrains | Date: 2017-04-25 13:38 | IP: IP Logged
I installed v5 today and I had F8 previously configured to launch a Perl compiler for the current file. It no longer launches the compiler, but does output:
Process completed, Exit Code 0.
Execution time: 00:00.097
It used to report "syntax ok" or errors if found, but not now, even if I introduce intentional syntax errors in my code.
Restoring back to v4.6.2 (2750) runs the compiler properly again.
Here's a screenshot of the compiler page:
imgur.com
Regards,
Vinnie
Edited 2 time(s). Last edit at 2017-04-25 13:47 by swbrains.
#2 Re: Version 5 compiler launch
Posted by: pspad | Date: 2017-04-25 14:27 | IP: IP Logged
Do you have build 187?
#3 Re: Version 5 compiler launch
Posted by: pspad | Date: 2017-04-26 12:45 | IP: IP Logged
I found a problem.
In the next compiler will have 2 modes:
1. run on the background
2. run on the foreground (default). This one mode is working ok with Perl.
