You are here: PSPad forum > English discussion forum > Re: Linux native version
Posted by: massimobalestra | Date: 2017-03-31 13:27 | IP: IP Logged
now that you use the last version of Delphi, would you be able to make a native Linux version? ( a version that does not need a windows emulator like wine).
If you are planning to cross compile I would be happy to do some test for you.
Posted by: doctorlai | Date: 2017-03-31 13:45 | IP: IP Logged
I think the latest Delphi compiler does not support GUI for Linux
compilation.
Delph 10.2 Tokyo just supports the Linux Server 64-bit (Ubuntu) native code
compliation.
On 31 March 2017 at 14:27, Massimo Balestra <''.phorum_html_encode('englishforum@pspad.com').''> wrote:
> Hi,
> native
> wine).
> you.
> forum.pspad.com
> PSPad freeware editor www.pspad.com
Posted by: pspad | Date: 2017-03-31 14:27 | IP: IP Logged
And anpther thing. Multiplatform application needs to be writen with different framework - not VCL. And I am afraid there is no syntax component
Posted by: MegaV0lt | Date: 2017-04-07 14:21 | IP: IP Logged
So no Linux Version possible? I also would like to have the Linux PSPad ;)
Es gibt zwei Methoden, fehlerfreie Programme zu schreiben. Aber nur die dritte funktioniert. [Murphy's Computer-Gesetz]
Posted by: pspad | Date: 2017-04-07 14:23 | IP: IP Logged
For now you can run it under WiNe
