You are here: PSPad forum > English discussion forum > Re: ini files get lost after crash
Posted by: Andreas | Date: 2017-03-29 13:40 | IP: IP Logged
Hello Jan,
my 5.0.0 156 and 161 crashes while opening a file (already sent you the file).
After that some setting files were deleted.
I restored last modified files from a backup.
- PSCache.BIN
- PSPad.INI
- Recent.INI
- PSPad_MU.ini
Can you fix this? I mean that files will not get lost after a crash?
Posted by: pspad | Date: 2017-03-29 13:48 | IP: IP Logged
First I need to know what is reason of crash.
PSPad itself has no mechanism to delete config files. There must happen something wrong...
I lost content of PSPad.ini only.
Edited 1 time(s). Last edit at 2017-03-29 13:52 by pspad.
Posted by: Andreas | Date: 2017-03-29 14:05 | IP: IP Logged
Reason should be clear. I did send you the bad file today via email.
Yes, maybe only the pspad.ini gets lost. I restored the last modified files as I did not want to make a diff on all those files first.
Posted by: pspad | Date: 2017-03-29 16:32 | IP: IP Logged
I know. Thank you for the file I found and fixed problem.
I will make some changes now yet and I will publish new build then.
Posted by: Andreas | Date: 2017-03-30 13:11 | IP: IP Logged
Thank you. With 5.0.0 163 I now can open the bad file. If pspad.ini will not get destroyed I will see on next crash.
