You are here: PSPad forum > English discussion forum > Ghost Window in a multi monitor environment
Posted by: Esgrimidor | Date: 03/28/2017 11:25 | IP: IP Logged
I have six monitors in the desktop.
In the main one appear in the center a small windows relating to pspad.
When minimize the main pspad window in the monitor to the right minimize also
When close this ghost window then closes pspad window in the second monitor too.
Screenshots :
Nice program indeed
Posted by: pspad | Date: 03/28/2017 11:32 | IP: IP Logged
Esgrimidor:I have six monitors in the desktop.
Hello. Are you sure it's a PSPad window? PSpad doesn't use pin icon as Window icon. It looks like another application adds it into Windows title.
Posted by: Esgrimidor | Date: 03/29/2017 15:35 | IP: IP Logged
The window is from Pspad.
The additional option in the window is from an old windows explorer addon FileBox eXtender.
This addon affects all windows, but the pspad window is the only one appear twice...
Until to this moment I have to detect other interactions.
Nice program indeed
Edited 1 time(s). Last edit at 03/29/2017 15:39 by Esgrimidor.
Posted by: Esgrimidor | Date: 04/01/2017 15:52 | IP: IP Logged
This don't happen in the laptop with the same addon and operating system windows 8.1
Best Regards
Nice program indeed
Posted by: pspad | Date: 04/01/2017 16:22 | IP: IP Logged
Hello, can you test version 5 from the developer forum?
It's compiled in the new developer tools and it's possible it will behave more inteligent.
Unpack it to any folder outside program files and run. It won't touch your current PSPad
Posted by: Esgrimidor | Date: 04/02/2017 13:06 | IP: IP Logged
Running to try.
Best Regards
Nice program indeed
Posted by: PSChrisJo | Date: 04/03/2017 09:42 | IP: IP Logged
kinda of a wierd question but why do you use 6 screens? I never tought about using more than 3 so wonder what kind of work you do? Regards // Chris
Posted by: Esgrimidor | Date: 04/05/2017 18:44 | IP: IP Logged
PSChrisJo:kinda of a wierd question but why do you use 6 screens? I never tought about using more than 3 so wonder what kind of work you do? Regards // Chris
Well. First the question.
It is not happening again !!!!!!. Problem solved.
Six monitors ? You are right. I have a difficult character I am full of insecurity and needs to have clear.
I have six because I can't have 12.
I use not for graphic requirements. I get nervous when I don't see the information. For me is confortable works with three (I turned off the other three). But six is heaven when I have a lot of information from different sources.
Best Regards
Nice program indeed
