You are here: PSPad forum > English discussion forum > [5.x] Bash Syntax highlighter
#1 [5.x] Bash Syntax highlighter
Posted by: MegaV0lt | Date: 03/25/2017 13:56 | IP: IP Logged
Still with Version 5.x the syntax highlighter handles comments (#) wrong.
Line 3 is ok, because it is no comment all.
Lines after line 3 then should all be comment, but some are not
Everything from line 25 on looks good, because its no comment
For testing: www.dropbox.com
If i switch the syntax to python all comments ar right. Of cours the lies from line 25 are bash specific
Es gibt zwei Methoden, fehlerfreie Programme zu schreiben. Aber nur die dritte funktioniert. [Murphy's Computer-Gesetz]
#2 Re: [5.x] Bash Syntax highlighter
Posted by: pspad | Date: 03/25/2017 19:50 | IP: IP Logged
Fix will be available in next build
