You are here: PSPad forum > English discussion forum > Re: How to stop auto bullets?
Posted by: therium | Date: 2017-03-20 13:37 | IP: IP Logged
Hi, I have a .MD file I'm editing with PSPad 4.6.1. Whenever I start a line with
* something here
and I hit RETURN, PSPad automatically puts a bullet on the next line. How do I stop this?
I've searched the options and I can't find anything for this.
Posted by: Stefan | Date: 2017-03-20 14:09 | IP: IP Logged
See here:
Developer forum - new builds > [Direct edit] Special settings explanation
forum.pspad.com
Since PSPad 4.3.1 beta (1989), Date: 07-20-2004
there are new features, available only through PSPad.ini in [Special settings] section
You can edit this settings direct in PSPad:
goto "Settings\Program Settings... "
and press the [Direct edit] button
on the left down side of the settings dialog box.
Search for "ContinueComment=1"
Explanation:
e.g. in C++ language (or PHP, Java, ...) try start comment: /* and then press Enter.
If ContinueComment=1, automatically is generated * on next line, aligned under previous
Change the '1' to '0'
ContinueComment=0
to disable that feature.
HTH?
