You are here: PSPad forum > English discussion forum > Re: Wish: User defined dialog box for Pv5-Scripting
#1 Wish: User defined dialog box for Pv5-Scripting
Posted by: Stefan | Date: 03/10/2017 08:50 | IP: IP Logged
While working on Scripting support with new Pv5,
perhaps this idea can be included...
Would be nice if we could create
User defined GUIs as used with the *.DEF files.
\PSPad\Context\HTML.DEF
DEFINE:
%href%=@O HREF=,href=,,html file (*.html;*.htm)|*.html;*.htm,"
%target%=@C target=,target=,,_blank;_parent;_self;_top,"
%title%=@E title=,title=,,,"
%id%=@C id=,id=,,[],"
USE:
[a | link]
<a %href% %target% %title% %id% %name% %style% %hrefx% %language% >§|</a>
Or smtg like that grinning smiley
#2 Re: Wish: User defined dialog box for Pv5-Scripting
Posted by: vbr | Date: 03/10/2017 22:49 | IP: IP Logged
It looks like, this might be an interesting addition to scripting interface, if simple gui dialogs could be build "out of the box".
In the current version 5... the previous limitations for handling unicode text are no longer relevant, which makes scripting more powerfull.
However, I guess, that a more complex settings might be needed comparing to code clips - text controls, possibly combo boxes, check boxes/radio boxes, settable buttons and possibly others.
Regards,
