You are here: PSPad forum > English discussion forum > Re: Delete a line until find the first point if found
#1 Delete a line until find the first point if found
Posted by: Esgrimidor | Date: 02/11/2017 17:41 | IP: IP Logged
I have a file with many lines and phrases.
Example of a line :
This is a line. This line have two phrases. Not have three.
Another line
This is the second line. Never give up.
I would like a script or search with regular expressions to replace the above lines with
Never give up
How can i do that ?
Best Regards
Nice program indeed
#2 Re: Delete a line until find the first point if found
Posted by: vbr | Date: 02/11/2017 20:35 | IP: IP Logged
Esgrimidor:
Example of a line :
Another line
Never give up
How can i do that ?
Best Regards
it seems, that something like the following regex replacement could work for you:
^([^.]*\.\s+)([^.]*)\..*
replace with:
$2
[x] Regular expressions
Make sure to check the ouput on your text sources - surprise is always possible with regexes, if various cornercases are not chechked for carefully.
hth,
#3 Re: Delete a line until find the first point if found
Posted by: Andreas | Date: 02/12/2017 17:37 | IP: IP Logged
You also can try this one:
^.*?\.\s*(.*?\.).*$|^.*$
Replace with:
$1
Explanation:
^ - start of string
$ - end of string
. - any single character
\s - any whitespace character
\. - period "."
* - zero or more
*? - zero or more ungreedy (lazy)
| - OR
#4 Re: Delete a line until find the first point if found
Posted by: Esgrimidor | Date: 02/14/2017 22:16 | IP: IP Logged
The scripts are functional and goes well.
After try I need this .
A script able to :
1. expand in the txt file each line discomposed by the point.
Example :
Until the first point. Phrase 2.Phrase 3. Phrase 4. Phrase 5.
"Until the first point" is deleted
And the original line now are four lines in the txt file :
Phrase 2
Phrase 3
Phrase 4
Phrase 5
and so on with the rest of lines of the original txt file.
One limit may be discompose the line in a maximum of 10 phrases . If are more then are not divided and mantain as the rest of line.
I don't know is pspad can do this. If not you can tell me another script able to do this with AutoIt or Autohotkey.
Best Regards
Nice program indeed
#5 Re: Delete a line until find the first point if found
Posted by: Andreas | Date: 02/14/2017 23:36 | IP: IP Logged
Look here e.g. regex101.com (https:// regex101.com/r/8v3tCH/1)
But I see you are showing some links to your(?) websites made with wordpress. Then you should not do such complicated things in PSPad. You can use PHP which is much easier. E.g. you can split a string first, then trim etc. Or try JS which also is mighty and can split, trim etc.
If you know wordpress do you also know Contao? contao.org I'm working with this CMS (try version 3.5.x not 4.x).
#6 Re: Delete a line until find the first point if found
Posted by: Esgrimidor | Date: 02/16/2017 21:47 | IP: IP Logged
Andreas:
Understood. Only say that I am not that clever one in wordpress. I go some months ago to a wordpress.org meeting.
But I am using wordpress.com and know nothing about PHP.
I will take a look to the links.
Best Regards
Nice program indeed
#7 Re: Delete a line until find the first point if found
Posted by: Andreas | Date: 02/17/2017 00:10 | IP: IP Logged
Here is a nice tutorial for PHP (http://) tut.php-quake.net. PHP also has a nice docu. Here you can see e.g. what you can do with strings (http://) php.net (/manual/en/ref.strings.php).
#8 Re: Delete a line until find the first point if found
Posted by: Esgrimidor | Date: 02/18/2017 00:26 | IP: IP Logged
\s*([^\.]*?\.)
\1\n
Why don't go with pspad ?
Nice program indeed
