You are here: PSPad forum > English discussion forum > Re: Syntax file complete documentation
Posted by: brolx | Date: 2017-01-26 13:08 | IP: IP Logged
Where can I find the complete documentation of all the entries in a syntax file?
I can only find the general info like in the help file.
Thanks
Posted by: pspad | Date: 2017-01-26 14:59 | IP: IP Logged
Menu settings / User highlighter. This is tool to create new user syntax file
Posted by: brolx | Date: 2017-01-27 07:43 | IP: IP Logged
Yes, the tool is great. However, even with that nice interface, I don't know the meaning of all options.
What is"vectors", "documentational comments", etc.?
Any complete info (even in bare spec format)?
Posted by: pspad | Date: 2017-01-27 08:00 | IP: IP Logged
It's specific for different language. Mathematicaly oriented languages uses special syntax for vetcors, some languages like PHP use different kind of block comments -. standard and documentation and you can set different colors for it.
This will be future of PSPad engine:
github.com
It has all syntaxes in external files with different format (JSON)
I don't think it's reasonable to put big effort to make detailed description of current user syntax file instead of the fix biggest problem in curent version and start work to move PSPad.
If you will have any question how to set something, don't be hesitate to ask.
Posted by: brolx | Date: 2017-01-27 11:07 | IP: IP Logged
OK Thanks a lot
