You are here: PSPad forum > English discussion forum > I continue with the save problem under windows 8.1
#1 I continue with the save problem under windows 8.1
Posted by: Esgrimidor | Date: 01/14/2017 13:58 | IP: IP Logged
It's the most strange thing.
In the portatile i can't save a file opened by pspad.
In the desktop i can.
But this is not only the difficult thing.
Lately the pspad get blocked for a little time.
Don't happen with any other program (notepad, notepad++, etc.)
My pspad version is 4.5.9 (2600)
I can't write , select o copy/paste.
I can't change tab.
Solve close and open again the program pspad.
But then i Lose the text line formatting.
And always i can save the file while opened.
I use these file intensivily to create new registers in my CRM Goldmine.
Last day I have to introduce more than 5000 registers and observe only 3 thousands were created.
I am saving the file while introducing. Perhaps was my error. I don't know well.
But for me it's strange the new pspad behaviour.
I usually introduce the new registers with the help of a virtual machine. So initianally seems to me to be in correlation, or even with the operating system, but seems proper of pspad.
In the portatile I cannot save the file opened by other application, but in the desktop i can .
Nice program indeed
#2 Re: I continue with the save problem under windows 8.1
Posted by: pspad | Date: 01/14/2017 18:27 | IP: IP Logged
Can you confirm it with current 4.6.2 build?
For test purposes you can backup and replace PSPad.exe only.
#3 Re: I continue with the save problem under windows 8.1
Posted by: Esgrimidor | Date: 01/15/2017 05:44 | IP: IP Logged
in the portatile the version is 4.5.9 (2600)
In the desktop I also can save the opened txt file with my application with notepad ++.
I am downloading the last version to try. I will inform.
Best Regards
Nice program indeed
#4 Re: I continue with the save problem under windows 8.1
Posted by: Esgrimidor | Date: 01/15/2017 19:59 | IP: IP Logged
I try in the desktop and happen the same about saving while the txt file is opened.
But happen also with notepad++
My problem is that in the portatile don't happen this with pspad.
I have windows 8.1
In the portatile is home version
and in the desktop professional version.
I am in despair, but now I don't think is for pspad.
The rest of problems i haven't reproduce or get reproduce until this moment.
Any idea is welcome
Best Regards
Nice program indeed
#5 Re: I continue with the save problem under windows 8.1
Posted by: pspad | Date: 01/15/2017 20:21 | IP: IP Logged
There must be something wrong with sharing between your real and virtualised system.
I use Virtual Box every day and I share real drive into virtualized system (Windows 10 or Windows XP). I didn't find problem you have.
Do you use current Guest extension? Do you use current Virtual Box?
#6 Re: I continue with the save problem under windows 8.1
Posted by: Esgrimidor | Date: 01/17/2017 12:57 | IP: IP Logged
But sharing is disabled in that virtual machine.
I have the last and use the guest tools
Nice program indeed
#7 Re: I continue with the save problem under windows 8.1
Posted by: Esgrimidor | Date: 01/18/2017 10:10 | IP: IP Logged
I continue with my problem.
Seems related with the operating system.
Best Regards
Nice program indeed
