You are here: PSPad forum > English discussion forum > Re: Default Syntax Highlighting
#1 Default Syntax Highlighting
Posted by: pconrad | Date: 01/11/2017 22:08 | IP: IP Logged
I work on a system that the files have no extension. I have created a user highlighter, and I have to select it each time I open a file. Is there a way to set a default highlighter that will engage on files with no extension?
#2 Re: Default Syntax Highlighting
Posted by: pspad | Date: 01/12/2017 06:04 | IP: IP Logged
If you want highlighter for files with no extension, you need to add mask into highlighter for files with no extension: *.
#3 Re: Default Syntax Highlighting
Posted by: pconrad | Date: 01/13/2017 17:26 | IP: IP Logged
That mask works great. Thank you!
Is there a way to have a default highlighter if there is no mask defined?
example:
I have a file named 1234.TEST. The .TEST is not defines in nay highlighter mask, but I always want to open as a specific type.
The extension could be any text, so limiting to a single mask is not possible.
#4 Re: Default Syntax Highlighting
Posted by: vbr | Date: 01/16/2017 19:55 | IP: IP Logged
pconrad:
I believe, you can add * as a general file mask to your needed default highlighter settings.
hth,
