You are here: PSPad forum > English discussion forum > Re: Special characters highlight or size
#1 Special characters highlight or size
Posted by: DenTNT | Date: 12/19/2016 10:34 | IP: IP Logged
Could not find the answer...
There is the option to show/hide special characters in the PSPad. But they are the same as usual characters and symbols. Is there a way to set a different color for special characters?
#2 Re: Special characters highlight or size
Posted by: pspad | Date: 12/19/2016 10:49 | IP: IP Logged
Try to set color for whitespace in highlighter settings / Colors
If you will set color in one highlighter and dblclick it, it will set it in all highlighters for same name attribute
#3 Re: Special characters highlight or size
Posted by: DenTNT | Date: 12/19/2016 13:36 | IP: IP Logged
How can I set these settings for TXT file type or *.*?
#4 Re: Special characters highlight or size
Posted by: pspad | Date: 12/19/2016 13:47 | IP: IP Logged
In case you need to change it, you must create empty use highlighter
But it isn't possible to do for *.*
I can add possibility of this setting to any next build
#5 Re: Special characters highlight or size
Posted by: DenTNT | Date: 12/19/2016 14:16 | IP: IP Logged
Thank you.
Btw, there is no way to set color for WHITESPACE in Highlighter setting... -> TXT -> Colors
#6 Re: Special characters highlight or size
Posted by: pspad | Date: 12/19/2016 16:21 | IP: IP Logged
There is an attribut with "space" name. Sorry.
#7 Re: Special characters highlight or size
Posted by: adrenochrome | Date: 03/01/2018 09:17 | IP: IP Logged
Sorry to revive this old thread, i just installed the developper version and i was expecting to find this option but i didnt
Edited 1 time(s). Last edit at 03/01/2018 09:17 by adrenochrome.
#8 Re: Special characters highlight or size
Posted by: pspad | Date: 03/01/2018 09:30 | IP: IP Logged
if you want to use highlighter for all files, use *. mask
