You are here: PSPad forum > English discussion forum > Re: Fast/Quick Open?
Posted by: giu | Date: 2016-12-02 09:09 | IP: IP Logged
There are a feature on Atom that I love, is the fast open. With Ctrl+p a "popup" appears and while I write, a list of files are filtered until I choose one, and I can do this without using the mouse.
There are something similar on PSPad?
Posted by: pspad | Date: 2016-12-02 09:34 | IP: IP Logged
There is list of open files in the left panel.
I can add this functionality.
Posted by: pspad | Date: 2016-12-02 13:56 | IP: IP Logged
This functionality will be available in next build in menu Widnow / Open file list
Default shosrtcut will be Ctrl+Alt+O (you can change it). Ctrl+P isn't free
Posted by: giu | Date: 2016-12-02 15:52 | IP: IP Logged
pspad:There is list of open files in the left panel.
Yes, but what if the file is not opened?
What I love is that...I have in my project a file called fac_cab_fac_s.php and fac_cab_fac_s-dv.js and I can, for example, use "filters" to open the file I want (in any subfolder)
For example:
CTRL+P
fac_cab <space> js
pspad:This functionality will be available in next build in menu Widnow / Open file list
Wow, this was fast lol
Posted by: pspad | Date: 2016-12-02 16:53 | IP: IP Logged
I missed your previousvmail. Can you describe your wanted behavior? I am afraid I don't fully understand what and where to search.
Posted by: giu | Date: 2016-12-04 09:18 | IP: IP Logged
pspad:I missed your previousvmail. Can you describe your wanted behavior? I am afraid I don't fully understand what and where to search.
I created a gif to show you.
How Atom does, is so powerfull. It searchs in all project subfolders.
Posted by: pspad | Date: 2016-12-04 17:21 | IP: IP Logged
Thank you for it.
On the left is project tree or folder tree?
My search I made works for project tree too. It will offer you result from open files or project files.
Posted by: giu | Date: 2016-12-06 08:32 | IP: IP Logged
pspad:Thank you for it.
Project tree in Atom is folder tree AFAIK
