You are here: PSPad forum > English discussion forum > Fast/Quick Open?
Fast/Quick Open?
#1 Fast/Quick Open?
Posted by: giu | Date: 12/02/2016 09:09 | IP: IP Logged
There are a feature on Atom that I love, is the fast open. With Ctrl+p a "popup" appears and while I write, a list of files are filtered until I choose one, and I can do this without using the mouse.
There are something similar on PSPad?
#2 Re: Fast/Quick Open?
Posted by: pspad | Date: 12/02/2016 09:34 | IP: IP Logged
There is list of open files in the left panel.
I can add this functionality.
#3 Re: Fast/Quick Open?
Posted by: pspad | Date: 12/02/2016 13:56 | IP: IP Logged
This functionality will be available in next build in menu Widnow / Open file list
Default shosrtcut will be Ctrl+Alt+O (you can change it). Ctrl+P isn't free
#4 Re: Fast/Quick Open?
Posted by: giu | Date: 12/02/2016 15:52 | IP: IP Logged
Yes, but what if the file is not opened?
What I love is that...I have in my project a file called fac_cab_fac_s.php and fac_cab_fac_s-dv.js and I can, for example, use "filters" to open the file I want (in any subfolder)
For example:
CTRL+P
fac_cab <space> js
#5 Re: Fast/Quick Open?
Wow, this was fast lol
#6 Re: Fast/Quick Open?
Posted by: pspad | Date: 12/02/2016 16:53 | IP: IP Logged
I missed your previousvmail. Can you describe your wanted behavior? I am afraid I don't fully understand what and where to search.
#7 Re: Fast/Quick Open?
Posted by: giu | Date: 12/04/2016 09:18 | IP: IP Logged
I created a gif to show you.
gph.is
How Atom does, is so powerfull. It searchs in all project subfolders.
#8 Re: Fast/Quick Open?
Posted by: pspad | Date: 12/04/2016 17:21 | IP: IP Logged
Thank you for it.
On the left is project tree or folder tree?
My search I made works for project tree too. It will offer you result from open files or project files.
#9 Re: Fast/Quick Open?
Posted by: giu | Date: 12/06/2016 08:32 | IP: IP Logged
Thank you for it.
Project tree in Atom is folder tree AFAIK
