You are here: PSPad forum > English discussion forum > Re: unix highlighter too aggressive with # inline comments
#1 unix highlighter too aggressive with # inline comments
Posted by: Mike4Online | Date: 2016-11-23 19:44 | IP: IP Logged
Jan,
Using PsPad 4.6.1 (2730), I found that in a unix shell script, any text following a # will be highlighted as a comment. But for # in the middle of a line, this should only be true if the # is preceeded by whitespace.
For example, the following shell script shows two comments in the PsPad highlighter:
#!/bin/bash
touch test1.txt
touch test#2.txt
touch test3.txt
ls test1.txt test#2.txt test3.txt
But there are no comments in the above script, which will execute as expected.
The need for whitespace before a # comment that is in the middle of the line is documented at the following link:
tldp.org
Thanks,
- Michael
#2 Re: unix highlighter too aggressive with # inline comments
Posted by: pspad | Date: 2016-11-24 11:32 | IP: IP Logged
Fixed. I also fixed escaped case \#
It will be available in the next build
