You are here: PSPad forum > English discussion forum > Re: Parsing external application log
Posted by: brolx | Date: 2016-11-23 11:26 | IP: IP Logged
Any way to parse the output of an external application?
The same way as for the compiler?
Posted by: pspad | Date: 2016-11-23 12:04 | IP: IP Logged
Using PSPad scripting you can fill in LOG window and setting log parser
Posted by: brolx | Date: 2016-11-25 17:20 | IP: IP Logged
The log window is filled.
The log parser is set for the compiler (I found no way to set it to the external tools).
Should I run a PSPad script to set the "current" log parser to be able to double click on the log window? That means that, after each external tool launch, I have to manually launch this script?
Posted by: brolx | Date: 2016-11-25 17:38 | IP: IP Logged
Indeed, if I run a script to set the log parser to what i expect, it works.
That means I have to create one script per external app and call it explicitely before or after calling an external app.
Could you add an entry to specify the parser for each external app? That would be a great time saver.
Thanks a lot
Posted by: pspad | Date: 2016-11-25 17:42 | IP: IP Logged
There is no possibility to set log parser e.t.c. for external application. But if you will look in the left panel ú Favourite TAB, there is possibility to define external application with compiler possibility. It means automatically load LOG content, set LOG parser, ...
Posted by: brolx | Date: 2016-11-28 09:30 | IP: IP Logged
I see, but this one cannot be applied to the currently open file, right?
Can't you add a log parser option in a next version? That would be so great!
Thanks a lot
Posted by: pspad | Date: 2016-11-28 10:07 | IP: IP Logged
Why it couldn't be applied to currently open file? It can be.
Favourite tab has same cabapilities as compiler
Posted by: brolx | Date: 2016-12-22 12:41 | IP: IP Logged
I see.
Anyway, it would be very handy (and orthogonal) to have it there also.
Please
