You are here: PSPad forum > English discussion forum > Re: Oracle SQL code explorer: "sequence" keyword issue
Posted by: metrino | Date: 2016-10-28 07:56 | IP: IP Logged
Hi.
I'm writing an Oracle SQL file that contains a package declaration / body.
It looks like the "sequence" keyword is mismatched in code explorer.
For instance, following statement
SELECT sequence_owner owner, sequence_name name, min_Value
, increment_by, DECODE(cycle_flag, 'N', 'NOCYCLE', 'CYCLE') vcycle
, DECODE(order_flag, 'N', 'NOORDER', 'ORDER') vorder
, DECODE(cache_size,0,'NOCACHE', 'CACHE '||cache_size) vcache
FROM all_sequences
WHERE sequence_owner = UPPER(TRIM(i_owner))
AND sequence_name = NVL(UPPER(TRIM(i_sequence)), sequence_name||'');
finds following (false positive) sequences:
_owner
s
_owner
_name
I suppose you have to add a "white" char after "sequence" keyword to make it works correctly
Posted by: pspad | Date: 2016-11-24 11:58 | IP: IP Logged
Fixed. Available in next build
