You are here: PSPad forum > English discussion forum > CSV Highighligting Syntax
#1 CSV Highighligting Syntax
Posted by: freuter | Date: 08/15/2016 09:59 | IP: IP Logged
Hi Folks and Cracks...
it should be great to have a separate Syntax-highlighter for semicolon separated CSV-Files - at least to get a better look, which one is for what named field, als shown in the first line.
How can i separate each founded semicolon and is there any way to count it in the first line and to check if the following lines are the same counted semicolons?
A complete example for any CSV Syntax highlighting should be great!
Thanks in advance for reading and answers - AND YOUR TIME to do that winking smiley
Kindest regards from germany and sorry for my lousy english grinning smiley
Life is a lousy adventure - but the graphics are just breathtaking winking smiley
#2 Re: CSV Highighligting Syntax
Posted by: Boomerang63 | Date: 01/09/2018 18:14 | IP: IP Logged
This day I had the same question.
I just wanted to find or build a highlighter, so that i can view csv files and I were disappointed that I couldnt find corresponding info.
And I am disappointed of me, that I couldnt manage to do it myself with PSpad help files.
For my first aid I downloaded CSVed.
But If anybody in this forum knows, whether building a special highlighting filter could lead to a proper csv editing help, then I would like to know.
Michael
#3 Re: CSV Highighligting Syntax
Posted by: pspad | Date: 01/09/2018 18:28 | IP: IP Logged
Look for user highlighter in the help file. Wizard is in the menu settings / user highlighter
#4 Re: CSV Highighligting Syntax
Posted by: khagaroth | Date: 01/13/2018 19:20 | IP: IP Logged
I don't think a CSV highlighter is possible with user highlighters. There are no keywords, just values separated by comma (or some other char, like tab or pipe), so it would require something like a "column" highlighter.
#5 Re: CSV Highighligting Syntax
Posted by: Andreas | Date: 01/18/2018 00:28 | IP: IP Logged
If I need a good overview I open the csv file with Calc from Open Office.
In PSPad you also can use the addon "allign column". Select all with Ctrl+a. Run the addon. Type in your seperator. And you're done.
