You are here: PSPad forum > English discussion forum > Feature request: decode in-place UTF-8
Posted by: Freeman | Date: 2016-07-26 15:09 | IP: IP Logged
Using Mercurial, sometimes broken UTF-8 appears, because Mercurial improperly detects it during file merge. Looks like this:
A flag that currency is used in system.
Признак используемой в системе валюты.
Used CONSTANT VARCHAR2(4) := 'Used';
Validation operationId
Рдентификатор операции валидации платежа РІ шлюзе.
First comment is normal Cyrillic, but second one isn't, should be "Идентификатор операции валидации".
I want a PSPad feature to in-place decode that broken UTF-8: select the block, then choose Edit → Special conversion → Decode UTF-8. PSPad should decode selected text as UTF-8 or display confirmation when selected block cannot be properly decoded, ask "Decode anyway? (Yes/No)".
