You are here: PSPad forum > English discussion forum > Re: PSPad 4.6.1 (2730) hash mismatch
Posted by: kaos | Date: 2016-07-09 16:03 | IP: IP Logged
The MD5 hash value shown for the installer at pspad.com and fosshub.com do not match.
pspad461_setup.exe hashes (downloaded file size 5,305,144 bytes)
pspad.com MD5: BC9C7BEC21C47F5AE3D6D6D0FFE9F495
fosshub.com's hashes:
PSPad installer - 5.06 MB | version: 4.6.1
MD5: a123bfcb4931b7a7a30bc960ad3c6312
SHA1: f9bc86221108e52b641b44b8abb158636972c4d2
SHA256: ca5e95bbb38ee55ed9adc9cb859cb87870fb9055b8011d70fad76a8bcee20238
the MD5 values on the two sites do not match.
However, they do match for the portable version, pspad461en.zip:
pspad.com MD5: e6654b180c22c288d51540bc926883de
and fosshub.com's hashes:
PSPad portable version - 5.61 MB | version: 4.6.1
SHA1: bec016589fd4515646bd9fafca4eab352c997912
SHA256: 49044a734c3b2cb1163ec3ad885a278a46ad612018ca545260ab0d68d225327f
Both downloaded files match the hash values published at pspad.com. The problem exists in the values at fosshub.com to check file integrity.
kaos
Edited 1 time(s). Last edit at 2016-07-09 16:09 by kaos.
Posted by: pspad | Date: 2016-07-09 16:28 | IP: IP Logged
PSPad installer is digitaly signed. If there is digital sign, you can be sure it's genuine.
I will contact fosshub admin.
Posted by: kaos | Date: 2016-07-09 16:37 | IP: IP Logged
The installation went fine. No problem there.
Just wanted to let you know about the mismatch.
Some people may check file integrity using the values posted as fosshub.com and not install PSPad because of it. Then, go elsewhere to find a text editor.
kaos
