You are here: PSPad forum > English discussion forum > Re: Close Tabs
Posted by: RobertA | Date: 2016-07-04 18:28 | IP: IP Logged
I've just had to move to a different laptop. ISTR the copy of PSPad I was using let me close tabs by click on an X in the right of the tab. I can no longer seem to do that or find a way to turn that on.
If my memory is incorrect (Possible and I don't have the other laptop here to check at the moment) might I suggest that for a feature? where the x shows up as the cursor passes over the right of the tab.
Robert
Posted by: pspad | Date: 2016-07-04 18:57 | IP: IP Logged
PSPad never has cros on the file tab.
You can close tab with dbl click, shift+click, middle button click, Ctrl+F4
