You are here: PSPad forum > English discussion forum > How to install Lorem Ipsum generator?
Posted by: therium | Date: 2016-06-21 12:18 | IP: IP Logged
PSPad 4.5.8
Under Tools, Lorem Ipsum generator, there is supposed to be a generator dictionary but I don't have one. The drop down box in the window that pops up is blank.
How do I Get one?
And how do I install it?
Thank you.
Posted by: pspad | Date: 2016-06-21 13:03 | IP: IP Logged
In the subfolder Spell should be file Lorem.txt
I looked into portable package and files are there. If you downloaded developer build, this build contains changed files only, not whole installation.
Posted by: therium | Date: 2016-06-21 15:39 | IP: IP Logged
I found lorem.txt in a newer version of PSPad. Thanks!
Posted by: Texter | Date: 2016-07-17 20:20 | IP: IP Logged
You can generate Lorem by using Emmet.js plugin. Just write for example lorem24 (24 words) and run emmet action.
Posted by: Andreas | Date: 2016-07-17 22:22 | IP: IP Logged
Thank you. Nice info.
