You are here: PSPad forum > English discussion forum > Search horizontal position
#1 Search horizontal position
Posted by: Josu0464 | Date: 2016-06-14 11:16 | IP: IP Logged
when I do a search, pspad centers on the line, the position of the searched word.
This makes it difficult to read the code, hidden on the left side of the screen.
In Settings / Editor 2 see I can change the vertical position (top, down, center, by default) appears in the search, but not the horizontal (left ?, right ?, center ?, ...)
Is it possible?
Kind regards,
Josu Vitorica
#2 Re: Search horizontal position
Posted by: pspad | Date: 2016-06-14 11:20 | IP: IP Logged
Your search result (searched word) isn't visible in the result line?
#3 Re: Search horizontal position
Posted by: Josu0464 | Date: 2016-06-20 12:57 | IP: IP Logged
Yes,
I.E.: I have a cobol program with these lines, and the screen wide is marked by "|":
| EVALUATE WS-FREC-PARAM-N |
| WHEN '30' |
| IF WS-SYS-HHMI >=800 AND WS-SYS-HHMI<=825 |
If I search 825 Pspad centers the word 825 in the line and shows:
|EC-PARAM-N |
Part of the code is hided in the left margin of the screen and we have to use the horizontal scroll bar to see it.
When we use the F3 to search the next ocurrence we have the same problem again.
