You are here: PSPad forum > English discussion forum > Re: Line comments not working in Visual LISP highlighter
Posted by: pkenewell | Date: 2016-05-25 13:40 | IP: IP Logged
Hi Jan,
I know this is late coming, but I have been having an issue with single line comments in Visual LISP that are put right after a closing bracket. This issue did not come up until the release of 4.6.0, which I am currently using.
(FYI - ";" is the comment character in Visual LISP, and ";|" and "|;" are the in-line comment chars.)
Examples:
(defun test ()(princ "Hello World")); This DOESN'T work
(defun test ()(princ "Hello World")) ; This DOES work
Please let me know if this has already been documented and fixed in a build of 4.6.1 - or if there is something else I can do in the settings.
This is not a big deal and I can live with it. just wanted to let you know its happening and find out if you have already noted this issue.
Thanks! - Phil Kenewell
Posted by: pkenewell | Date: 2016-05-25 14:08 | IP: IP Logged
P.S. Sorry I should be more clear - the Syntax Highlighting is what is not working for comments placed right after a closing bracket.
Posted by: pkenewell | Date: 2016-06-27 14:42 | IP: IP Logged
No reply? Do you need more info, or was it something I said?
Posted by: pspad | Date: 2016-06-27 14:49 | IP: IP Logged
Sorry. I overlooked it. I will try to fix it in next build
Posted by: pkenewell | Date: 2016-06-27 14:57 | IP: IP Logged
Thanks. No problem.
Posted by: pkenewell | Date: 2016-08-19 14:54 | IP: IP Logged
pspad:Sorry. I overlooked it. I will try to fix it in next build
THANKS! I installed the new version 4.6.1 and it's good again. Much Appreciated!
