You are here: PSPad forum > English discussion forum > Re: broken autocomplete since windows 10
Posted by: kenny1930 | Date: 2016-05-19 11:41 | IP: IP Logged
after upgrading to windows 10 the autocomplete in pspad is not working properly.
After taking one proposal my cursor is always losing his focus.
Is there a special setting to do?
I'm using version 4.6.0
Thanks in advance
Posted by: pspad | Date: 2016-05-19 12:57 | IP: IP Logged
Can you give me any example please? Sample text, highlighter you use and what to do.
Posted by: kenny1930 | Date: 2016-05-22 07:43 | IP: IP Logged
I'm using the standard highlighter for php.
After typing "in" into the editor autocomplete is making me some suggestions
After i select one in the list with space,tab or mouse my cursor
is not after the selected word in the text. I always have to click into
my document to work further.
I'm using Pspad Editor for years and this problem is only there after
upgrading to windows 10.
Posted by: pspad | Date: 2016-05-22 11:24 | IP: IP Logged
I just tested it but didn't find anything worng.
Can you send me your PSPad.INI into support mail? It must be something config depended.
You can find PSpad easy in by going to Program settings / Backup and clicking on the path above backup/restore buttons.
Posted by: pspad | Date: 2016-05-24 05:19 | IP: IP Logged
I tested it with your configuration file and again - I didn't find nothing wrong.
What PSpad version do you use?
Download current developer buid www.pspad.com and replace existing files
