You are here: PSPad forum > English discussion forum > save highlighter format for copy / paste to Word?
#1 save highlighter format for copy / paste to Word?
Posted by: john3774 | Date: 2016-03-26 19:25 | IP: IP Logged
Hi -
I am using one of the supplied highlighters with PSPad. It works fine. I would like to copy/paste the file into Word so that the highlighting is maintained.
In looking around, it seems there are various ways to do this from different IDEs or editors, if one does certain things in Word. However, I'm not sure if it can be done from PSPad - It appears that the formatting is always lost.
Does anyone have any suggestions?
Best regards,
John
#2 Re: save highlighter format for copy / paste to Word?
Posted by: pspad | Date: 2016-03-26 19:55 | IP: IP Logged
Select text you want to paste nito Word and use menu File / Export / Export to clipboard as RTF (Ctrl+Ins).
Same option is on the right mouse context menu under Paste special.
