You are here: PSPad forum > English discussion forum > Re: Is it possible to highlight unclosed quotes?
Posted by: lostymosty | Date: 2016-02-24 12:17 | IP: IP Logged
For example.
"Blah,blah,blah" // green highlighted.
"Text text text // red highlighted
Or...
Highlight string. If it has odd numbers of quotes with red and if it has even number of quotes with green?
Posted by: pspad | Date: 2016-02-24 12:21 | IP: IP Logged
Strings are highlighted with colors you set in menu settings / highlighter settings for each highlighter.
Unclosed string highlights rest of the line as string.
Posted by: lostymosty | Date: 2016-02-24 13:46 | IP: IP Logged
Dear Pspad,
thank you for your quick answer.
I try to explain with image, what i want.
Is it possible to do so?
Edited 1 time(s). Last edit at 2016-02-24 13:50 by lostymosty.
Posted by: lostymosty | Date: 2016-02-24 15:00 | IP: IP Logged
I found the solution, i'll use the php-syntax. It wokrs.
But how can i set up the custom highlighter like php-highlighter?
PHP-Syntax Highlighter:
