You are here: PSPad forum > English discussion forum > Re: Close All empties the project file as well
Posted by: KennyT | Date: 2016-02-19 09:06 | IP: IP Logged
After a while my set of tabs becomes "unwieldy" because i've got so many open files. But if I try to use the "Close all" option, the files disappear from my "tree" in the LH pane.
is there a less "brutal" option that only closes all the open tabs?
K
Posted by: pspad | Date: 2016-02-19 09:10 | IP: IP Logged
I guess you use project.
Right click on the project root and choose close folder files. It will close all project files.
Posted by: KennyT | Date: 2016-02-19 12:03 | IP: IP Logged
thanks! works a treat!
K
