You are here: PSPad forum > English discussion forum > Re: Search and Replace Newlines
Posted by: WebUpdateWizard | Date: 2016-01-15 13:12 | IP: IP Logged
I'm really silly or maybe this is a bug, but given the following text...
Pete
Liz
Sarah
Kate
.. I would like to replace the newline (line break) characters with commas, so that all 4 names are on a single line.
I think this is a regular expression '\n' as the search criterion but it doesn't seem to work.
Any suggestions appreciated, thanks!
Pete
Developer of the Web Update Wizard - add automatic updates to your software with 1 line of code! Visit www.PowerProgrammer.co.uk for more information!
Posted by: vbr | Date: 2016-01-15 21:23 | IP: IP Logged
WebUpdateWizard:Hi,
Pete
unfortunately, this is a limitation of the current search and replace engine of PSPad;
if your text is that simple (single word per line), you can use: Edit: Lines manipulation: Join lines
and replace the spaces with commas afterwards.
Otherwise scripting can be used for this.
hth,
Posted by: WebUpdateWizard | Date: 2016-01-16 12:52 | IP: IP Logged
Thank you for taking the trouble to respond. Appreciated!
Pete
Posted by: Andreas | Date: 2016-01-16 21:24 | IP: IP Logged
You also can use the addon phreplace phdesign.com.au
It's fast and comfortable. Use the enter key within the search or replace text for a newline.
