You are here: PSPad forum > English discussion forum > Re: Macro feature does not function in Windows-10
Posted by: hlk123 | Date: 2016-01-09 18:29 | IP: IP Logged
Since recently I use Windows-10.
Now I cannot use "PSPad Macro" because if I press Ctrl+F5 then Windows-10 reacts so as if I search for a computer .. and I get an error message from "active directory" .. etc.
What can I do? .. because I need the Macro feature of PSPad.
Thank you.
Posted by: hlk123 | Date: 2016-01-09 18:50 | IP: IP Logged
and other problem:
I cannot use the key F3 for "find next" ... why? Thank you
Edited 1 time(s). Last edit at 2016-01-09 18:52 by hlk123.
Posted by: pspad | Date: 2016-01-09 22:01 | IP: IP Logged
Investigate, which application you have installed uses Global ShortCut.
Any application can register global shortcut - usually graphics drivers, mediaplayers, maybe some cloud folder synchronization...
Check your system tray (application with icons near) and their settings
Posted by: vbr | Date: 2016-01-10 00:08 | IP: IP Logged
hlk123:HelloSince recently I use Windows-10.
Thank you.
Hi, if you can't find or disable the program assigned to this shortcut, you can probably change the shortcut to some other "free" combination:
Program settings: Key Map: Makro: ...
hth,
Edited 1 time(s). Last edit at 2016-01-10 00:08 by vbr.
Posted by: hlk123 | Date: 2016-01-13 07:50 | IP: IP Logged
In BIOS I changed the "Function Key Behavior" to "Function Key".
Now the keyboard behaves like standard....
That is the solution.
