You are here: PSPad forum > English discussion forum > PSPad won't remove HTML
Posted by: therium | Date: 2015-11-13 13:09 | IP: IP Logged
I have PSPad 4.5.8 (2482). When I have a text file that has html in it, I go to the menu HTML > Conversion, but the "Remove HTML tags" is grayed out. The same thing happens when I select text I want to process, that item is grayed out.
Does this look at the file extension only to enable that "Remove HTML tags" menu item? Becuase it shouldn't. I have .MD files with HTML in them that will end up as Markdown only, and I need to remove all html from them.
Is this a bug?
Thank you. You have a great text editor, and I have 25 years experience looking for great text editors.
Posted by: pspad | Date: 2015-11-13 13:24 | IP: IP Logged
It's grayed, cause highlighter in your case is TEXT. Change highlighter to HTML.
YOu can use menu view, tollbar button or click on the highlighter name on statusbar.
